Hi all,
I need to install the following bath tap to the wall:
Below is a photo of the 1/2 BSP connector at the back of the tap:
I am intending on cutting a channel in the tiles for each of the 15mm water pipe (using my angle grinder and a diamond blade) and then connect the above connectors to push-fit wall plate elbows 15mm x 1/2 BSP:
I have a few questions as I have never done it:
1) I need to do this with minimum damage as I am trying to retain as many tiles as possible (the tiles are really old and I would like to preserve as many as possible), is there a way to remove tiles from walls without breaking/damaging them?
2) When connecting the 1/2 BSP connector to the wall plate elbow, can I just use PTFE tape or should I use a leak sealer instead? Or both of them?
3) I read the reviews for those wall plate elbows, they should normally be able to take the weight of the tap, would you agree?
4) Would the wall plate elbow normally fully sit inside the wall? Or shall the tip of the BSP connector on the wall plate elbow be flush with the surrounding tiles?
5) How big (i.e. wide) the hole shall be to fit those wall plate elbows? (I have not purchased them yet, trying to understand which diamond holesaw to get)
Thanks!
Thanks!
