I'm currently fitting a new bathroom suite and have a wall mounted set of bath taps to fit. The wall fittings to the taps have a 3/4" BSP connection and will be mounted on a stud wall.
As there's not much room in the stud cavity, I need to use a 3/4" elbow fitting on the back of the taps. I'm planning on using 15mm Speedfit pipes throughout the installation and wanted to use a JG elbow at the taps - but I can't find one! Does anyone know if JG do a connector for this application?
If not, what is the alternative? I've found this (click here) on Screwfix - can I use it, then reduce it to 15mm to connect up with the Speedfit stuff?
Thanks for your advice.
