I need to replace a bath tap which is leaking.
The existing tap is connected with JG Speedfit pipe and tap connectors. They are the metal type like the below, not the plastic ones.
Can I simply swap the tap and connect the tap connectors to the new one, or should I replace the black washer?
If it needs replacing, what type of washer is it?
JG Speedfit Plastic Push-Fit Straight Tap Connector 15mm x 3/4" - Screwfix
Order online at Screwfix.com. Push straight onto copper tube. Removable and reusable. Water Research Council Approved. British Gas Service approved for water pipes. No tools needed. FREE next day delivery available, free collection in 1 minute.
www.screwfix.com
