Fair enough.To come back to this, the electrical threads I was referring to were for things with a hole like conduits, with minimum OD (for PG7) 12.5mm.
I don't know about that, but what I was talking about are the M3.5 machine screws used to attach the front plates of virtually all standard UK electrical accessories, hence with countless examples in every UK building (hence very 'ubiquitous'!).I assume 3.5mm dia is for things like threaded studs for spade connections.
I don't have a spec. Maybe not a 'standard diameter,' and certainly only commonly seen in the electrical context, but they do exist more generally, as in ...Do you have a spec for them? I don't think it's the same as a metric bolt, as 3.5mm is not a standard diameter. Bolt standards are M1.6, M2, M2.5, M3, M4, M5, M6, M8 ...etc.
