How do I strip the outer jacket of a cable without damage to the inside of it? With a tight fitting cable, it takes a lot of effort.
While using heat gun on thick 4:1 heat shrink, if the heat isn't high enough, the shrink doesn't shrink. If the heat is high enough, it also melts the cable. So, how can this work?
