Does this look like an asbestos garage roof to you?
12 Dec 2014
Birmingham
Obviously I’m going to get a test or survey before messing with it, but I’m just wondering because our mortgage valuation said ‘suspected asbestos’ but a couple of different family members who work in the building trade said it doesn’t look like asbestos to them.
I don't think I would trust your family members! ;)
There's not really a discernible difference between non-asbestos and asbestos, cement sheets.
Sometimes there may be markings on the sheets; and there may be dimples in asbestos sheets, due to the manufacturing process.
Otherwise, there may be no way of telling just by sight (...and without knowing the age of the sheets).
As above, get it tested to be sure.
What's the best thing to do to get it confirmed. A DIY test or is it the sort of thing you need to get someone out for (if so, what kind of surveyor do I need)?
Looks like it to me.
DIY testing is cheap.
Risk as is is low
Careful dismantling is safe with proper precautions
small leaks may be easier to treat from inside, any removal of stuff on the outside creates issues.
You could try silicone inside
Risk as is is low
Silicone? I thought my options were duct tape for a quick fix or bitumen to do it properly?
Mainly for peace of mind or just to know what I have on my hands. Although there are a couple of small leaks also which I will need to patch.
It’s almost certainly asbestos.
To repair cracks etc, I use a garden sprayer to wet the asbestos sheet, scrub clean the area with a wire brush, then wash off the scrapings with the sprayer. Allow to dry, or force dry with a heat gun, then paint with flashband primer, then apply some flashband, use a roller and a heat gun to really seal.
wear suitable mask and if you want a disposable suit
