- Joined
- 24 Aug 2009
- Messages
- 2,723
- Reaction score
- 293
- Country
I was back _in the UK a few weeks ago and had the full cambelt/auxiliary belt plus w/pump/tensioners replaced @100 000 - this at a "known" garage.
On the return journey - immediately on fast dual-carriageways/motorways - I noticed fairly quickly that the temp gauge wasn't moving off its stop, and only did so when I slowed down and was driving through Dover town 70 miles further on*. This seems like a hell of a coincidence, but can anyone think of any reason why a change of coolant should induce a thermostat failure ?
Now, a few weeks later, with 15 C weather the other day in the valley, the needle rose up to about 70 C on the flat , but then hit the usual 90 C when I climbed the mountain to return home. I do very few short trips, mainly longer ones at 25 miles , so would this be a problem if I left it for a few months ? I ask this in the light of a thread I recently read about oil in a Micra where the talk veered onto sludge production at lower temps. I'm looking to keep the car as long as possible, so my question is in the light of "long-term reliability "
Whilst talking about oil, I wasn't able to get the recommended GM Dexos2 5-30 ( which is ACEA C3 ) but bought a store-branded ( like Halfords) 5-30 which is ACEA A5/B5, in preparation for my next change. On returning home i checked this and the store web-site ** says "not recommended" for my car.
I haven't had anything to do with ACEA before , so I looked up the various notations and find that A5 is:
"ACEA A5/B5 oils are Upper Mainline lubricants. They are designed for use in high performance gasoline and light duty diesel engines that are specifically designed to use a low viscosity oil. These oils may be unsuitable for use in some engines. "
Not included in this, is that these are also regarded as "Longlife" oils for extended periods before change. This oil seems to be the top spec, whereas the C3 Dexos is mid-range. The Longlife aspect doesn't affect me as I'm only doing about 7 000 miles/yr and changing oil yearly.
Anybody have any insight into why this would be "not recommended "*, what might make it "unsuitable for some engines " and what are their feelings about my using it.
* I did stop early on and check coolant in tank.
** I maybe shouldn't pay too much attention to this site, because it also listed the wrong oil-filter for my engine on a previous occasion.
Looking forward to your informed responses
