I've laid cable for an extension to a ring circuit, but am rethinking where I break in. This ring carries nearly all of the sockets in the upstairs of the house. I have a 16A breaker in the consumer unit that is currently feeding 3 sockets to a small porch area that is a radial. I'm thinking of using this instead for the new sockets.
I have full access to the radial cable, and the new sockets, in an adjacent room will be fed under upstairs floor boards (around 8 or 9m away). The new sockets are all connected but not live, with two tails. Originally, I was going to extend the ring but if I use this radial circuit instead can I just extend the new tails to the 16a cable and wire in serial ie extending the radial as is:
1. Snip Porch tail
2. Connect each new extension tail to either end of the 16a
Or is it allowed to just connect one of these new tails from the existing 16a cable, and then I terminate the resulting tail?
Other things to note: previous electrician put a 13a fused spur before the porch sockets. There is no return to the consumer unit so this is a radial, but I would be break in prior to this. Not sure why the 13a fuse was put in.
The new sockets are driving a TV, fridge and lamps etc. All cabling is 2.5mm2 and there are 7 new double sockets in total.
1. Snip Porch tail
