- Joined
- 28 Feb 2022
- Messages
- 88
- Reaction score
- 3
- Country
That span only needs 4 x 2 anyway.
warm roof would be 95mm + 11mm OSB + 120mm insulation + 18mm OSB then add on firrings if joists are set plumb
is that too much roof thickness, 245mm
Sadly there is no way to achieve building regs elemental values with 130mmneed it about 130mm
yes I think i might have to. what is the minimum insulation thickness of cold roof and minimum air gap?Sadly there is no way to achieve building regs elemental values with 130mm
you might need to redesign.
Check this thread: https://www.diynot.com/diy/threads/inverted-warm-roof.590522/
You might be able to get close to what you want
thank you and @Notch7 for you help, i am very thankful.I'm no expert I'm afraid! Plenty on here though.
You will need to make some sort of change to your design, as your BCO will make you to ensure it is compliant, unless as above you can prove energy saving elsewhere...
