Install of Nest to replace Hive (Greenstar 28i Junior)
9 Oct 2009
Bristol
I have moved into a property that has a Hive System (just the basic one for a combi i.e central heating only and not water )installed and I want to switch it for my Nest 3rd Gen.
Presumably N to N,
L to L
The earth seems to be hanging there, so I will need to check the other end of the earth is connected to an earth. (Either to the metal casing/mount, or into boiler earth connection).
Does the 3 on the Hive go to the 3 on the nest
The 1 on the Hive goes to the 2 on the nest
Anything else I need to do?
It’s a combi boiler, hot water side not required.
