- Joined
- 17 Jan 2016
- Messages
- 114
- Reaction score
- 4
- Country
Cheers.They are discharges for expansion.
Need to get the UV serviced.
Cheers.
It is the larger of the two pipes that is dripping but, surprisingly, there is no dripping of water into the tundish by the cylinder which also indicates servicing of the air gap in the cylinder according to instructions fixed to the cylinder.Is it the larger or the smaller of the pipes? If you do have an unvented HW cylinder and it's the larger of the pipes that's dripping/running then get the cylinder serviced.
If it's the smaller pipe then you need the boiler serviced.
Attached are two relief valves connected to the cylinder.You may also have a expansion relief valve installed as part of a group set which comprises a PRV set to 3bar, a NRV and then the expansion valve set to 6bar, can you check this, if installed.
If it's installed correctly, both the cold water expansion PRV (on the control set) and the T&PRV should discharge into the same tundish, that then provides a localised visual indicator that the UV needs looked at.there is no dripping of water into the tundish by the cylinder which also indicates servicing of the air gap in the cylinder according to instructions fixed to the cylinder.
