One of my sons has a 2012 Ford Galaxy, 2-litre petrol, which has been playing up. To make it harder to diagnose, it’s very intermittent.
Past few weeks it’s been slow to start or taken two attempts to start. Filled up a near empty tank (possible red herring) then it stalled twice when pulling away at junction / roundabout.
Next day driven fine on a long-ish drive (hour each way)
Few days later again slow to start and stalled again at roundabout then stalled when driving after, low revs/weak acceleration. Engine wouldn’t restart. Got it home via breakdown truck - engine either not starting or stalling after 5-10 seconds. Few days later collected by breakdown chap to be taken to garage, car started fine.
Garage scanned it and came up with attached report. The codes were then cleared, car taken for a run, scanned again and the codes didn’t reappear (a bit odd to my mind). So maybe the fault has cleared itself and he just needs to keep using it and see what happens.
I'm not too impressed by the report, and if the codes had come back I would want to know
He WFH so not desperately urgent, but it needs sorting. I suggested maybe an “Italian tune-up”, but he’s recently returned from France where he did some brisk autoroute driving, luckily the problem didn’t start over there.
Any suggestions appreciated!
- Fuel rail pressure - is that a problem with the sensor or something else?
- Fuel supply control - what does improbable mean? If there is a problem with the control unit that might explain the symptoms.
- Engine start malfunction - explain. Is it a fuel or spark problem or what?
- Vehicle speed signal - is there a problem with that? I suppose the computer needs to know the speed so a fault could give the symptoms.
