End part of gutter.
27 Mar 2009
Essex
I accidentally knocked the end part off with a ladder but now can't see any way to attach/click it back into place as the clip part just butts up to the plastic clip already on the length that is still attached to the fascia. I can't work out if the clip parts were originally attached by being glued together. Any advice would be greatly appreciated. Thanks HH
Have you possibly lost a small filler length of gutter, that may have fallen down unoticed?
You seem to have knocked the gutter along, needs pushing back to wall then stop end will clip back on.
Thanks everyone.
I'll have a look around in the morning to see if I can find anything on the ground. What would the cutting look like? Would it be pretty easy/obvious to fit?
Thanks everyone.
Yes, it should be obvious - just a very short piece of guttering! :)
Don't think so. It is an outlet screwed to the wall. As above piece of gutter missing.
Thanks everyone.
See if you can find the rubber gasket while you're there.
I would just move gutter bracket along about an inch and end stop would fit .
You have a rubber gasket in the stop end thats the important part .
