Getting 12 volt from 48 volt supply?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
My e-bike is 48 volt, my tyre pump is 12 volt, battery encapsulated, is there an easy way to drop volts?
At moment I rely on an aerosol can to reflate tyres when out, touch wood, never needed to use it, but bike has a 12 Ah 48 volt battery, can't think of any way to use it, maybe one one else can?
Search for "DC to DC converter"
And select one that covers 50V and 12V
And has a wattage (or current) rating that matches your inflator.
This one is likely over rated (wattage wise) for your needs
And I would say that random Grinch suggestion is likely better than mine as encapsulated and fixed voltage.
My e-bike is 48 volt, my tyre pump is 12 volt, battery encapsulated, is there an easy way to drop volts? At moment I rely on an aerosol can to reflate tyres when out, touch wood, never needed to use it, but bike has a 12 Ah 48 volt battery, can't think of any way to use it, maybe one one else can?
The DC-DC converters that have been suggested are the obvious approach.
However, roughly how much current does your tyre pump draw at 12V?
Why not an ordinary hand cycle pump?
A 12v 3amp series regulator is cheap and the fact they waste current would not be much of an issue for short use, but the last I was involved with were only speced to 30v. No doubt the 30v limit will have improved since then, or run two in series.
Trying to find one last week as it happens. Very hard to source a components at the moment. *Very* few have 48V input capability. I don't think the time to blow up a tire is short enough to ignore heating effects. And for linear regulators running from the same sort you can't run them in series.
My tyre inflater is 12V 45A a surprising number are in excess of 10A.
I'd have thought a hand pump would be fine for the rare times they need pumping up.
Not come across any with that sort of demand on 12v, the only 12v ones I have seen plug into the ciggy lighter socket.
I agree, it only takes a minute with a hand pump. Out of curiosity, a few weeks ago I tried one of those bike pumps where you stand on the base and operate with two hands - to blow up a car tyre. It was perfectly doable.
My tyre inflater is 12V 45A ....
Good grief! My car one claims to be 6A (at 12V) and I think all the car ones are designed to be plugged into the ciggy socket, which is usually/often fused at 10A. How do you power your 45A one?
