How to Use Parallel Guide on Router
10 Sep 2012
Cornwall
Hi, I have a hand-held (not table) router and it came with a parallel guide. Dumb question, but how is it best to use this?
Let's say I am routing the edge off a plank. If I butt the parallel guide against the opposite edge, then I need to be very sure that I keep it pressed hard against there. If it deviates, I'll be routing into the 'wanted' piece, ruining it. Also, do I have to be particularly careful to avoid climb-cutting in this configuration, as the piece might get dangerously pinched between the cutting bit and the guide?
So I could butt it against the side I'm cutting, then any accidental deviation will cause the router blade to wander away and off onto the 'scrap' piece, which can be corrected by doing another pass. However this destabilises the parallel guide because the trailing side of it is pressing against nothing....it's following a path of an edge that isn't there any more because I just cut it off :D
If I'm routing a groove then the same applies - the guide can only fully protect against deviation on one side. The only thing stopping it wandering in the other direction is keeping a good constant pressure on it. Am I missing something?
I very rarely use a parallel guide.
In fact, i only use it for things not too important to be perfect.
There are router bits with integrated guide, so they shave just what's needed by applying a small pressure on the side to finish.
This is very useful with decorative profiles for frames, shelves, etc., but you need a straight edge to start with.
Anything else, i use aluminium guides.
They're basically long clamps with a straight edge; a lot more precise than parallel guides.
i recently had to cut a small grove near the edge of a bit MDF and used a guide , i also added a guide on the other side - but made sure it did not pinch at all
Also move the router in the right direction , so its feeding correctly against the router rotation
I used a 1/8th single flute cutter , as i wanted a narrow grove to slot a bit of perspex into
If you are, you are not the only one. I don't use routers that often but when I did I had the same problems you are having. Ruined 2 worktop jigs in the process:mad:
Material to the left, cutter to the right of that, side fence ("parallel guide" - side fence is what most people call them outside of manufacturers manuals) to the right of that - work by pushing the router away from you, never pulling towards you. The router is pushed forwards and slightly to the left (easy as the cut will naturally assist) Do NOT use the fence on the left-hand side of the material as this traps the material and can lead to a climb cut. Going round the outside of a piece you always go anti-clockwise - going round the inside (e.g a mirror or picture frame, using a bearing-guided cutter) you work clockwise - this is so the "material to the left/cutter to the right and push the tool away from you" rule is always followed
The thing about fences is that they invariably have a gap in the middle - but it can be better to take off the bits of plastic on your fence (if it has any) and replace it with a single piece of hardwood or plywood. This needs to be deeper than the cutter so that it forms a single piece sub-fence, and can be much longer than the length of the metal fence if needs be. You may need to position the plywood sub-fence and plunge the cutter into it to form a clearance pocket. Using a long fence like this helps avoid the "jinking" you can experience as the cutter reaches the end of the material
No, you aren't (missing something). You need to follow the rule I stated above - material to the left, cutter to the right, fence (if any) to the right of the cutter and push the router away from you (NOT towards you). This avoids a climb cut.
The other thing which avoids climb cutting is not making too wide a pass - if you want to cut a 20mm wide rebate, but you only have a 12mm diameter straight cutter, you need to make something like 4 passes, eac h 5mm further in from the edge than the previous. This is so that on an edge cut you never have more than 1/2 of the diameter of the cutter working in the material (i.e. 1/2 of 12mm - 6mm). If you tried to do this cut in two, say, 10mm passes you'd not only potentially overload a smaller router. but you risk a kickback caused by the climb cutting action of the cutter as it exits the material. Incidentally, this is another job a side fence does better than any other technique, and which bearing guided cutters either cannot do at all or are have very limited capability in
It is possible to set-up grooving in some circumstances (on narrower material) with two fences and longer fence rods, but I've rarely ever needed to do this. One example, though, used to be cutting 15 or 20mm intumescent strip grooves in the edges of 44mm thick fire doors where two fences, longer fence rods and a single deep plywood sub fence made for a faster and less error-prone job out on site in the days before a specialised intumescent strip groove cutter became available.
I still use the same sort of technique when I have to groove-out the bottom edges of doors to accept drop seals, in which case the door is rested on a pair of trestles and a large plywood sub fence is needed on the upper parallel guide (the 1/2in router is used on its' side and the plywood sub-fence is needed to help support the weight
You were using a worktop jig with a side fence? :unsure:
People sometimes ruin them by pulling the router out of the jig without first unplunging the cutter (and locking the plunge mechanism), switching off and letting the cutter stop first. I don't do this most of the time (I just unplunge), but if a piece is critical or I don't have much material to spare I do become ultra cautious. I also stopped loaning jigs to people a very long time back because of the way they get abused
The other common mistake is to do with direction of cut. You always need to cut into the laminate, so this means right hand end male/right hand end vfemale cuts are done with the jig on the top face, left hand end male/left hand end female cuts are done from the bottom face, and the cut depth is increased over 3 or 4 passes with the router alwsys being pushed away from your body. The other thing people are iften unaware of is that on many jigs the groove that the 30mm guide bush runs in is actually deliberately oversize - this is partly so that you can make your 3 or 4 stepped depth cuts with the guide bush deliberately pulled over to run against the right hsnd side of the groove and the final, full depth pass of a fraction of a millimetre being made with the guide bush run against the left side of the groove. Gives a cleaner edge and a better joint fit
Sorry for the long post, but there were a lot of points
Never cut a parallel groove? Or a centre of panel bead? Both those need to be perfect and require a fence
The problem with them is that they don't handle the sorts of cuts I mentioned above. The range of profiles is also limited. They cannot be run against a shallow edge (because the guide bearing generally requires another 6 to 10mm of edge depth), and finally they follow minor discrepancies in the edge, and the smaller the diameter of the bearing the more marked this effect (and smsll diameter bearing bits are also more likely to push into pin holes, voids, or soft spots in the edge), whereas a long fence evens them out. So bearing-guided cutters aren't always the right choice (BTW, I do use a lot of them, it's just that they aren't a universal panacea)
I beg to differ - a properly set-up side fence is just as accurate - and doesn't depend on you setting the parallel strips you are working with precisely parallel. That doesn't mean I don't use auxiliary fences - one task they can't be beaten for is cutting housing across narrow timbers (e.g the housing joint on a rebated door casing). I have made up a guide fence/square arrangement for just this purpose many, many times over the years
Thank you for all the replies, I understand I think. I called the item a parallel guide rather than a fence, because when I Googled this prior to posting, all the search results with "fence" in were relating to table routers, so I figured that might be the wrong terminology to use here. I do own a lot of router bits with the ball-race guides on them, but on this occasion I need a straight edge. I think I will instead make a fence that is clamped to the workpiece and run along that.
thats what i did, and thought you meant that , you clamped a guide to the workpiece - sorry misunderstood
I have an old Dewalt DW625 router. Half of the fence was missing when I purchased it years ago. Have since purchased the requisite parts but as a novice, I appreciate that I need to apply pressure against it to ensure that it doesn't deviate,.
I think the problem comes from the fact that as supplied all router fences have this girt great hole min the middle which makes it very difficult to control as you reach the end of the workpiece. Even I find that awkward with a big router like the DW625 or that monster OF2200e that I have. So I treat it exactly the same way I would treat a spidle moulder or even a router table - and make my own fence. I think that there is a pre-conception that tool manufacturers always supply tools which work right straight out of the box and is unchanging, like a spanner. Well, that simply isn't true - and if you ever get into collecting old hand tools you'll end up discovering a fair few tools which have obviously been modified from what the manufacturer delivered into what the user needed. Actually, of all the power tools, routers are probably the most customisable of all, and providing you are prepared to put a little time, thought and effort into using them they are probably one of the more versatile power tools
Part of this explains why I think the idea of putting an edge moulding on using a straight edge as a guide is so terrible when a simple user tweak makes the tool much more useable
