pyronix alarm - wireless low batt
20 Dec 2013
London
Hi all for a fairly old alarm pyronix 8-9 years old maybe but I’ve only had a couple of years as new homeowner
I believe attach shows that one of the sensors has low battery?
Can anybody pls advise how to change battery?
(I have “engineers code”)
I don’t want it going off whilst I try replace it..
Also what type of battery does it take? Then I can have ready before I try replace….
Sorry, not an expert, but Pyronix lists two types of sensor battery on its website:
So it will be a 3V lithium CR2, or a CR123A. You may have to investigate the sensors further and tell us what you have.
...and if one battery is going, it's probably worth changing them in the rest of your sensors, while you're at it! :)
Show us a photo of the inputs and we can work out what batteries or alternatively punch in the engineers code, open the sensors up to check what batteries are needed, order them up and do this again to change them when they come
You are as well changing them all
Yes,change all the batteries in all your devices at the same time,this way you stop any other battery faults as you do not know how old the existing one's are.
Pls see attached the sensor
I think they are CR123A
I will enter engineer code tonight and open sensors to check
And yes replace all same time - good point!!
Will any batteries do or do people recommend a particular brand - or maybe rechargeable ones ?
I was thinking of these
CR123A 3V Lithium Battery, 6 Pack 1600mAh CR123A Disposable Batteries for Alarm System Polaroid Camera Torch Remote Toys - Non-Rechargeable
Hi I punched in engineers code - didn’t go on any particular setting - just left on engineer menu.
And when I opened the sensor with screwdriver - the alarm started beeping off!
Was I meant to select a particular option before opening ??
What did display say after entering engineer code.
When in engineering you show be able to open lids without any noise.
Either not in engineering correctly or wrong code.
Unfortunately it says something else now….see attached please
Before I’m not sure what it said…but it’s certainly yeh right code cos you can press yes to “exit engineer menu” after u keep pressing no….
Not sure what to do now - any help appreciated please!
Your system is asking for an engineer reset.
Go into engineering ,change all batteries then exit engineering should clear fault.
Once you have cleared fault you then go into engineering and change alarm restore from engineer reset to user and turn off anti code reset as well.
But when I go into engineering do I select any particular option or just enter my engineer code so I’m In menu ..
Ok so I went into menu and replaced the Batteries of all sensors
I set the alarm and let it ring out (so that I get a text message) cos I’m approaching the 180 days Vodafone give before a sim expires
Unfortunately although the siren outside rang and panel inside rang - no text was received as per usual…..any reason for this?
I need to get a text in the next few days as I’m on day 177 lol
You heed to check that the sim card is still live,best way is to put sim in an old phone.Make sure you power unit down before you take/ put sim card in as this can damage module.
I could do but
Last time I let 180 days lapse - an error message came up on the panel….not such error this time
Also I rang Vodafone who told
Me sim is live. I was also able to check the credit on the account by dialling from another Vodafone sim …..
So it’s all very strange considering I used to get messages before…
