No mate. The utility cupboard is on the ground floor.Is it up stairs? is there a loft? Surely you can find a junction box on the upstairs light circuit in the loft? This would save down fusing a light spur
Are the FCUs still bith feeding immersions?Is it possible to create a light feed and spur from the FCU's?
Yes, they are.Are the FCUs still bith feeding immersions?
In that case, I would say that it somewhat depends on what sort of loads you are contemplating might be plugged into the socket you want, since, when the immersion is 'on' it will already be using virtually all of the power available on the 'load side' of the FCU and probably the great majority of power available on the 'supply side' of it (if it is a 16A circuit). Hence, unless you are fairly sure that the only loads ever applied to the socket will be fairly 'trivial', it doesn't sound like a good idea.Yes, they are.
See ....If by 'spur' you mean a socket, ...
I would like a light and a socket in my utility cupboard. ....
Indeed ....then it depends upon what use you intend putting the new socket to.
I would like the following in the socket - Internet modem, NVR and maybe a PC monitor. Is this okay?In that case, I would say that it somewhat depends on what sort of loads you are contemplating might be plugged into the socket you want, since, when the immersion is 'on' it will already be using virtually all of the power available on the 'load side' of the FCU and probably the great majority of power available on the 'supply side' of it (if it is a 16A circuit). Hence, unless you are fairly sure that the only loads ever applied to the socket will be fairly 'trivial', it doesn't sound like a good idea.
Also to be consdiered, if you connect a socket and/or lighting to that circuit, you will invoke a require for the circuit to be RCD protected. Are the immersion circuits currently protected by RCD(s)?
Unfortunately, the feed is at the switch. So it will be very inconvenient trying to extend the feed to the new lightIs there a reason you cannot supply the light feed from your existing lighting circuit?
I guess on the rare occassion, it would be convenient to hook up a hoover (Henry) to clean the area. However, I am guessing that this wouldn't be wise as the power could cause the the circuit to trip?
Which? Either could be quite a large load.it would be convenient to hook up a hoover (Henry) to clean the area.
