Ugh! Ive just tried fitting the foam filler (for my 34/1000 profile sheets) and theres too much slack on the thin section! (the highers sections fit fine):
View attachment 279475View attachment 279476
Ive contacted the foam filler company and they say its not the right measurements for their 34/1000 profile.
I presumed all 34/1000 profiles would be the same measurements?!
Your sheets appear to be identical to the ones on both my garage and my workshop, which are intended to be installed with the wider part (71mm??) sat down on the support joists. I bought the foam filler and it fitted perfectly, narrow section uppermost, wide section down and trapped between metal sheet and the timber. I can only guess that some of the metal sheet is designed to fit the other way up, with filler strip to match. I notice you still have that rubber strip in place, if those photos are current.
