My central heating is on microbore, which is blocked in places and most the rads are full of sludge, so the system needs gutted. I know in the living room, the microbore pipework was just jammed between a gap in the floorboards, wouldn't surprise me if the rest of the flat was in a similar shoddy state. Since the floorboards and carpet need to come up, I figure it's a chance to sort out the floor too.
My flat is in a 200 year old tenement building on the 3rd floor and the floorboards feel dreadful through the carpet. They're uneven, creaky, and there's dips in the carpet like chunks of the floorboard are missing and the previous owner just foam underlay and carpeted over it.
I'm guessing replacing all the floorboards will be expensive (can you mix and match original tongue and groove floorboards with modern floorboards or they different sizes/thicknesses now?).
I was thinking to just nail down any loose boards, replace the worst looking ones, 6mm plywood on top screwed down, caulk the joins of the ply sheets, a self levelling compound over the top, underlay, then laminate on top.
Does that sound like the best way to do it?
