Soffit grommet ?
10 Dec 2008
Jersey Marine
I have a cable with pre-terminated plugs on either end ....
This needs to be fed vertical up through a soffit, it would be nice to get some form of grommet/bulkhead seal, to seal the hole and around the cable, rather than using silicone.
The plug that has to go through is 22mm in diameter - so that is clearance needed ...... once it is passed through the 'grommet' only has to seal around the cable ... which is 7mm diameter.
It's passing through 6mm plywood, I have seen a few back entry grommets, but they expect to be used on socket boxes ... 2-3mm thick
Any suggestions ?
Doesn't need to be IP65 or similar, just to neaten the hole and prevent rain from blowing up into soffit.
Yes have access both sides ...
Unfortunately 22mm glands only allow a diameter of up to 12mm and the plug is 22mm
Even 25mm glands will only pass through 18mm cable.
Maybe I'll just have to adapt a SWA gland PVC shroud, unless someone has something better.
Split cable glands are definately a thing you can buy. I haven't used them myself though.
For example I found https://www.icotek.com/en-gb/products/cable-glands/qvt a system of splittable glands that comes in various sizes (you would want the 25mm I guess) with inserts for various sizes of cable. The thread is apparently 13mm long so that should be plenty for your plywood,
I've come across this looking for a solution.
I need to pass 4 poe cctv cables up into my loft and now the roofs covered. If I'd have known the rj45 plug was on the cable in advance I'd have predrilled the soffit then added self adhesive flat cable grommet to the top side of the soffit. Might be able to reach through still, but i cant on the gable verges.
