Hi folks,
Replacing a broken surface-mounted backbox (light switch) with a metal, recessed one:http://www.wickes.co.uk/1-gang-metal-box/invt/205261/
It has a pre-made hole in one side, perfect position for the cable (which is under the plaster) but normal grommets don't fit in the hole. Hole is not sharp around the bit in contact with the cable (although it is at the top - it is formed so that the sharp edges face "upwards").
Is a grommet needed here?
Thanks,
Mark
Thanks,
Mark
