I have a cable with pre-terminated plugs on either end ....
This needs to be fed vertical up through a soffit, it would be nice to get some form of grommet/bulkhead seal, to seal the hole and around the cable, rather than using silicone.
The plug that has to go through is 22mm in diameter - so that is clearance needed ...... once it is passed through the 'grommet' only has to seal around the cable ... which is 7mm diameter.
It's passing through 6mm plywood, I have seen a few back entry grommets, but they expect to be used on socket boxes ... 2-3mm thick
Any suggestions ?
Doesn't need to be IP65 or similar, just to neaten the hole and prevent rain from blowing up into soffit.
Any suggestions ?
