Ok. That doesn't really help much - 10,000 or 20,000 since then.Ok thanks. The last reading I took a year ago was 30119
Looking again, I can see that if the meter was read a 1000kWh earlier, the dial would well and truly be below 5....Looks like 40804 to me
Eh? You know those dials advance continuously on gears, not jump in steps? Like a clock where the minute hand points to 6, the hour hand is half way between two other numbers.Looks like 40804 to me
I really can't agree with that, has there been a typo?51084
Do you mean right (rather than left)?refer to the number on the left
Yes & as the minute hand gets to 59 the hour hand is almost touching the next highest number.Eh? You know those dials advance continuously on gears, not jump in steps? Like a clock where the minute hand points to 6, the hour hand is half way between two other numbers.
How do you get the 10000 hand to point to "very nearly 5" when the 1000 hand points to "nearly 0" and call that 40000? Sure, the 10000 hand should be pointing to 10% past the 5 if the 1000 hand is pointing to 1, so it looks slightly wonky, but it's a gross underread to assert its pointing to the 4
