- Joined
- 2 Dec 2004
- Messages
- 738
- Reaction score
- 8
- Country
Hi all,
Expansion vessel failed I think - water flows straight out the shraeder valve when depressed.
Going to give full backstory though because I need to decide how to proceed.
I moved into a new house only a month ago. The boiler was serviced back in March 2022 and as part of the house sale this service certificate is obviously something that was supplied to me - all pretty standard checks from the solicitor.
On me taking ownership of the house, first I discover that the boiler pressure gauge does not work.
So I call up the person that serviced the boiler back in March, the previous owner of the house had used him for some time (his sticker was on the boiler).
He came and had a look, then went away to order part etc. Anyway 2 weeks later (I didn't use the heating at all during this time), he came back to replace the gauge, started up the heating, said all working ok, and left.
A few hours later I notice that the pressure is up over 3 bar. I drain some off from a rad in the kitchen.
Pressure is going from <1 bar cold to >2.5 bar hot.
I read up on this, check a few online videos, and give the shrader valve a little push. Water floods out.
So:
Boiler only serviced in March 2022. I find it unlikely that the expansion vessel and pressure gauge both happen to fail in the time between this service and me taking ownership, I think there is a reasonable chance these problems already existed.
Which means I can't trust the guy that serviced it, as it wasn't identified during the service or when he came to swap the pressure gauge.
I don't know whether to give this person a chance to explain/correct the issue, or write him off and go to someone else straight away.
Boiler is a Worcester Bosch Greenstar 25Si mk4 installed in May 2013 so its only 9 years old.
Need to get this repaired obviously. What would you do?
So:
