- Joined
- 2 Dec 2004
- Messages
- 738
- Reaction score
- 8
- Country
The boiler drain should be underneath the boiler with the gas supply, flow&return isolating valves, etc. I would be a bit wary of shuting those boiler isolating valves as they may drip on re opening them.
On my boiler the drain is inside the cover, and Im not supposed to remove the cover because it has seals as part of the combustion safety system.
On the outside of the boiler on the heating pipework, there is a drain valve, but this would drain down the whole system.
Boiler has been on for half an hour now and system is up to temp. Started at approx 0.75 bar the gauge now reads approx 1.25. So that trick with the radiator seems to have helped.To use a rad as a temporary EV, shut both rad valves, open rad vent, slacken connectio n to rad at one end, drain off all water, retighten connection, shut rad vent, open one only rad isol valve, preferably the return , re fill system to no more than 0.75bar
I am leaning towards this British Gas repair option: https://www.britishgas.co.uk/home-services/boilers-and-heating/boiler-and-heating-repair.html
It will mean a £75 initial cost of the repair including parts, then a £15 per month boiler cover scheme for a year. Total cost over a year £255 which seems good value considering the repair alone will probably be more than that. Plus then I get protection from any more failures.
