Hello,
What is the proper and most cost effective way to do a foundation if you are looking to have a flush floor finish with external ground level while bearing in mind some form of dpc is needed
This is for a steel frame garden room (single storey outbuilding).
So I.e. no subframe above ground level that would take away 150mm or so internal height from the 2.5m height limitation. And if doing a concrete pad this would have to finish at the same height as external ground level.
