If you are minded to insulate from below, then you are better off fixing Celotex (50mm or more if you can) and then plasterboard. This is more efficient and cheaper than the equivalent thickness of insulated PB.
You can overboard. Fix with long enough black phosphate plasterboard screws max 200mm spacing, you only need a couple of screws to hold the Celotex first before PB. Foil tape all insulation joints.
Yes, if you can slide some insulation down the slope in the loft it would help, but may not necessarily be essential. It depends on what you want to achieve, how much you want to spend and how much messing about you want to do
