- Joined
- 22 Feb 2022
- Messages
- 98
- Reaction score
- 2
- Country
Hi, I want to draught proof and insulate my hinged loft hatch - i've bought some foil insulation to stick on the inside of the hatch on the door that swings down...
The foil is quite thin, my plan was to staple it to the wood to fix in place along with some aluminium tape which I was going to line the hatch recess with too
Can I layer the aluminium foil by a few sheets to improve the amount of insulation or will this be inefficient? Also, to create a tight seal I bought some weather strip to stick around the edges
Does the above sound like the right way to go about it or am I being stupid?
Also we are getting a fair few draughts in our 30's build home, we recently had karndean laid on the flooring with insulation underneath but there are a few smalls gaps between the flooring and the skirting board. I know we have airbricks under the floorboards so I'm assuming draughts are coming through these
My plan was to stuff the gaps with weatherstrip to remove the draughts - then possibly seal with clear silicone or the like. Is this a good idea and could it potentially cause any damp issues?
