Hi
I’m installing a new combi boiler with new flow and return as part of an extension, and this will feed the existing flow and return in the existing house, and then go on to feed new radiators in the extension.
I’m doing it all in copper with regular end feed fittings.
My question is, what is the best way to install as much of the pipe work now, but leave it so that I can easily add the new rads later (each time I do up a new room, I’ll want the rad to go live, so there’s about five different times I’ll need to add a rad).
I was going to put the 22/22/15 tees in now, but then how do I leave the 15 branch?
If I put the 15mm pipe in to the rad location and just cap it off, then when I fill and pressurise the system, there will be a load of dead end air in there that’s gonna maybe sit there or worse start to slowly work it’s way out and my auto air vent / deaerator will release it and I’m going to be fighting with pressure drops all the time.
Alternatively i add a short stub to the tee and then cap that off but then I’ve got to unsolder the stub out the tee which I’d prefer not to do.. (unless it’s the only way)
Or I could fit full bore valves to every 15mm branch of the tees but I don’t like the idea of having ten valves hidden away forever that could cause problems down the line.
The way I’ve designed the system I can fairly easily drain down the new flow and return to mess with the tees later. But surely there must be a way of just blocking off a branch without de-soldering later on?
Any other ideas?
Thanks!
Any other ideas?
Thanks!
