Advice - what size end caps do I need to isolate bar shower when removed??
5 Jan 2009
Hi All
I’m wondering what size end caps I need to isolate the H and C that goes to a bar shower when removed.
I’m my mind I’m thinking it might be 3/4” BSP?
Or is it bigger?
Plus will I not need some firm of rubber/nylon washer to put in place as well??
And if you dont have iso valves fitted now would be a good time to fit a pair of the full bore type.
What do you mean by fitting full bore type.
Confused tbh.
Do you just mean standard 15 or 22mm iso ball valves?
I think there are isolation valves somewhere under the flooring but don’t want to lift it all as it’s glued laminate.
Are you saying there’s a way to fit isolation valves at the bar??
Cheers.
