- Joined
- 7 Sep 2022
- Messages
- 4,742
- Reaction score
- 1,383
- Country
Tube is easier imho, the grey stuff doesn't bend but you can get self adhesive black stuff that does
Oh one more, sorry.
For lagging i forgot to ask. Does it make a huge difference if it’s the wool wrap type or foam tube type?
Doesn't make sense to me; the tube shaped stuff that goes around pipes is insulation and that's a lot closer to the pipe than 100mmWill do thanks,
I read plumbing pipes should have a clearance of 100mm or so from the insulation too. So sensible just to stick to that as a rough guide?
width: before you unroll the roll, put a saw through the whole thing at the width you want plus a little. Let your wool expand back to its normal size on the floor befor picking it up and pushing it between joists and dont over compress it - it doesn't take much to stop it expanding back and you want it fluffed up as deep as possibleWidth - The Combi roll I bought (1140mm width) can be split into 3 lots of 380mm so i think that will be fine, presuming I can squish the 380mm into a 300mm wide gap without any issues?
Depth - With the depths at 150mm, assuming vertically compressing the 200mm roll a little bit here is also fine? Or better to let it bulge a bit if I use bird netting rather than chicken wire for example?
