View attachment 287892 A bit like this.
So it’s not connected to main soffit ?It's sealed. I checked this last year.
To be honest I'm not sure. I guess it's worth looking up there again one day and taking it apart. I still have the Storm Dry, so if anything, I can coat the brick and reseal the facia. Probably not the best weather now though.So it’s not connected to main soffit ?
Oh, I see. Yes, I've done a fair amount of research in this area and I do none of the above nowadays (apart from breath), yet I still have high
humidity. I could probably do with opening the windows more rather than first thing in the morning for 10 mins.
I have fairly decent extraction (Manrose MF100T) in the attics for both bathrooms.
I'd love to get MVHR, but I have a few more important things to do first
Don’t see how you can confirm it’s sealed if you don’t know if it’s connected to the rest ?To be honest I'm not sure. I guess it's worth looking up there again one day and taking it apart. I still have the Storm Dry, so if anything, I can coat the brick and reseal the facia. Probably not the best weather now though.
When I was last up the ladder, I checked and it was sealed with some form of sealant. I wasn't checking at the time if it was connected to the soffits, but the image shows that it does screw to the side of the house which joins the facia boards.Don’t see how you can confirm it’s sealed if you don’t know if it’s connected to the rest ?
Having sealant around the outside does not confirm it’s sealed from moisture if it’s open to the main soffit .When I was last up the ladder, I checked and it was sealed with some form of sealant. I wasn't checking at the time if it was connected to the soffits, but the image shows that it does screw to the side of the house which joins the facia boards.
Fair enough, I'm happy to investigate. What would you suggest I need to do then? I've never taken apart facia or soffits, so don't know how they should be.Having sealant around the outside does not confirm it’s sealed from moisture if it’s open to the main soffit .
