I am trying to install a Drayton Wiser kit 1 on my combi boiler & I want to confirm the wiring as it is an old boiler - attached is the wiring diagram for my existing setup with a room thermostat and a mechanical clock & below is what is required for the Drayton, I can take the neutral & live from the fused spur on the boiler so no issues there, I want to remove the stat and the clock from the boiler so if I remove the wires I assume I will then wire the 3 lines from the prog section of my boiler to the Drayton but does this sound correct.
Prog Input to Drayton com 1
Prog Neutral to Drayon off 2
Prog Live to Drayton on 3
Is this correct or is there something else I am missing ?
Thanks in advance
Demo
Thanks in advance
Demo
