wait till its cold and look at the pressure then , see if above 1 bar
the old photos - was that hot or cold
i notice the other post - no leak found...... and the pressure is 1.2bar ish
mine used to vary a lot on the boiler - from something like 1.1 to 1.8 ish i think - it was a brand new combi bolier installed around 2017 - we also moved out the same year
i just check mine every now and again as the loop is in the loft (although is in the boiler in the utility room), boiler changed in 2007- and make sure its above 1bar
it would drop in pressure every 3months - we tried a lot of things to fix, in the end our plumber adding some fenox leak stuff
Eventually we did find a possible source where air was getting in on an elbow in the loft , when we had a kitchen refitted they had to move the pipework and found it - no sign of a leak, but it was not soldered correctly and just pulled apart
when the pressure vessel broke on mine the pressure did go up to 3bar and overflowed through the relief valve
