- Joined
- 8 Oct 2015
- Messages
- 12
- Reaction score
- 0
- Country
Hi All,
We've had Indesit DFG 15B1 UK dishwasher which we have had for about 6 years.
Very gradually it has started to have an issue with syphoning back the water from the sink trap.
I first noticed this about 6 months ago where after the dishwashing cycle was finished the sump would be full up to the top of the filter food filter with waste water.
Catching it immediately at the end of the cycle the sump would be clear (so it is definitely draining) but over about 30 minutes the level would gradually creep up.
Since then it has got steadily worse, and now after a drain cycle ends either during operation or at the end about 10 seconds later there will be a gurgling from the sink.
If I force it to drain by starting a new wash empty, opening the door and cancelling the wash cycle (hold the power button for a few seconds) which continues to run the drain pump for about 20 seconds you can see the sump completely empty, after the pump shuts off the level immediately starts going back up and within about 30 seconds dirty waste water is back up to the top of the filter.
I've verified it's not leakage of incoming fresh water by turning off the cold supply when doing the same test.
The pipe arrangement we have is not ideal as the waste pipe in the back of the kitchen unit is quite high and too high to use the U-bracket supplied with the machine (which is long gone now) however I have always had a loop of the drain pipe cable tied to be well above the level of the outgoing drain:
I've disassembled and cleaned all the pipe work in the photo a couple of times since the problem started, and I've also tested the drain pipe heading through the back of the unit is clear and will accept a high flow rate without backing up, and nothing has changed about the configuration of the pipework in years.
So the problem seems to be the machine itself but after having the machine apart (and not for the first time) I'm at a loss to explain how it wouldn't syphon back ???
If you search for this type of problem online nearly all hits refer to a problem with the "air vent" in the drain hose, but this seems to be a very North American thing where they seem to have an actual air vent that is actually mounted in the counter top to allow the waste water from the dishwasher to separate at the vent and drain back separately to the sink trap and dishwasher after the pump shuts off to avoid syphoning.
But we don't have those kind of counter top air vents in the drain hoses of dishwashers in the UK so none of those articles are relevant. Since there is no air vent I assumed there must be a solenoid operated valve that shuts the flow off completely after the pump turns off.
But no, there is nothing of the sort in the machine. The water literally goes from the sump directly to an impeller style pump and then to the drain hose. No solenoids or one way valves or anything that could prevent syphoning the sink trap back into the sump of the dishwasher.
So what am I missing here ? Looking at the pipe layout it does occur to me that the point where the dishwasher attaches to the trap will be lower than the natural settling level of the trap - which will be in line with the bottom of the right angle bend in the foreground - so there is certainly potential for syphoning there despite the high arching loop, but if so, how did it operate for 5 years without syphoning back into the machine ? What changed ?
Unfortunately the height of the drain pipe through the back of the unit is above the level of the trap and I can't change that.
About the only thing that I can think of that might help would be to change the pipe section with the cable tie on it to one with a joint for the dishwasher to connect there, downstream of the trap level, but I'm not convinced that that would completely prevent syphoning.
Any suggestions anyone ? Is it the machine at fault or the pipe layout ? And if it's the pipes why did I not see a problem for 5 years then suddenly its got much worse very quickly ?
Currently the machine is partially apart on the middle of the kitchen floor and now that I'm not sure whether the machine or the piping is to blame I'm not sure what my next step is..
