Following the upgrade from Win10 to 11, I thought this problem might have resolved itself, but I was wrong - they still do not work. Clicking does nothing.
One solution I found, supposed to fix these problems, was described here - https://www.guidingtech.com/top-ways-to-fix-default-apps-missing-on-windows-11/
It suggested running Powershell, as Administrator, with the following line...
Get-AppXPackage | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)AppXManifest.xml"}
Note - it misses the essential '}' from the end of the line when you copy and paste from the site, but this is the result when I try to run it...
Anyone see what is going amiss please? There are many more similar lines of 'path not found', which I have not included..
PS C:\Users\harry> Get-AppXPackage | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)AppXManifest.xml"}
Add-AppxPackage : Cannot find path 'C:\Windows\SystemApps\Microsoft.UI.Xaml.CBS_8wekyb3d8bbweAppXManifest.xml' because it does not
exist.
At line:1 char:28
+ ... | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.I ...
+ CategoryInfo : ObjectNotFound: (C:\Windows\Syst...ppXManifest.xml:String) [Add-AppxPackage], ItemNotFoundException
+ FullyQualifiedErrorId : PathNotFound,Microsoft.Windows.Appx.PackageManager.Commands.AddAppxPackageCommand
Add-AppxPackage : Cannot find path 'C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewyAppXManifest.xml'
because it does not exist.
At line:1 char:28
Add-AppxPackage : Cannot find path 'C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewyAppXManifest.xml' because it does not
exist.
At line:1 char:28
exist.
At line:1 char:28
At line:1 char:28
exist.
At line:1 char:28
