I've had work done on my bathroom, with a new mixer tap installed on the bath and the hot and cold water flow from the bath tap is pitiful. The hot is coming out at 2.5 litres/minute
I have a older central heating system, with a hot water cylinder in the loft and my bathroom's on the first floor, so it would seem to be a low pressure system. My first thought was that I have bought taps which are unsuitable for low pressure, but I checked and they are supposed to be suitable for both high and low pressure.
The water pipes come into the bathroom as 22mm pipes and the plumber has run two 15mm spurs off it, with flexipipe going up to the taps. This would be the obvious explanation for the low flow.
If I turn the cold water on full, when the hot water is already on full, there is no increase in flow from the mixer spout, so I also wondered whether the taps themselves might also be to blame.
Is there anything else that could be causing this?
