Can someone help me wire 2 new lights into an existing 2-gang dimmable switch? AKA how does this even work at the moment?
10 Dec 2022
Described the situation in the image - I have a 2-gang dimmable switch on the wall that had 2 extra wires added in, when the new lights came installed.
The new lights are now here and installed, but for the life of me I can't figure out this wiring and how the neutral is not even wired into an L1 or L2.
What I would like to get is to have the 2 new lights on the same gang as the Nr 2 on the picture.
Neutral wires are not switched , only the live .Your question suggests a complete lack of electrical knowledge .
Your lighting ring passes thru the switch , not common but not unusual .
Are you in a block of flats ?
It's not; it is going from here TO com otherwise the switches would have no power.
Looks more like the loop in and out to me.
If as you say, then there would be no power to the existing switches and lights.
Hmm. Does your electrical experience include lighting circuits provided as rings? I've never seen one.
Oh, Lord, I must have caught something from Winston1!
I meant a light circuit fed off the ring main , my in laws home had this as ceiling were concrete slabs .
