I have a Glow Worm Flexicom 24CX boiler, which came with the flat (new-build flat, although remained unoccupied or two years, hence why the warranty on the boiler had expired when we moved in). Pretty much since day 1 the boiler makes a "howling" sound whenever it fires up, i.e. when ignition starts rather than the water pump. Sometimes it is a very loud howl, sometimes it's faint and sometimes there is no howl at all. Sometimes there is even a double-howl. I have tried to capture the noise in this video (sound on). Again, just to be clear, it is when the "flame ignites" so to speak and it happens both when using hot water (system without cylinder) or the central heating. It is only when it starts and does not continue afterwards - of course, if the central heating turns off the flame and then ignites it again, then there is usually a howl.
Everyone in this building has the same boiler and I have heard similar howling coming from other flats so I'm assuming it's something to do with the boiler itself. A guy came to service the boiler one day but, annoyingly, when he came there was no howling so he just said that it was what it was and left it at that.
Any thoughts on what it could be and whether it is repairable?
