Setting an Automatic Balancing Valve
9 Nov 2009
Edinburgh
Any tips on setting an ABV?
I did read somewhere that an old timer's trick was to close all rads and set the ABV to it's highest setting then open 30% of the rads and keep opening the ABV until it started to flow. Thoughts please.
Should be able to give a few pointers if you can reply to the following questions.
Have you got a oil or gas boiler?
If the pump is external post the make/model/mode/setting.
also post the ABV make/model.
Have you got a number of 2 port motorized valves or just one 3 port mid position motorized valve?
