Can you expand on that a little?Isolation by logic control is not permitted.
Quite simply, I suggest you read regulation 537.2.Can you expand on that a little?
I agree with the regulation entirely and I’m fiercely agreeing with you that physical isolation is the only truly safe means of doing this.Quite simply, I suggest you read regulation 537.2.
SAFE isolation is always, always by a mechanical means. Once a circuit has been determined as being safely isolated, it is locked off by old fashioned things like padlocks.
Unfortunately the regs isn't up to date in modern techniques. In summary it says (see last line)
Isolation: 537.2
Every circuit / installation must be provided with a method of isolation from the supply. This isolation device should also be provided with a method to prevent unintentional or inadvertent reinstating (usually lockable).
In a TN-S or TN-C-S system it is not necessary to isolate / switch the neutral conductor providing that it is ‘reliably’ connected to Earth on the distributors incoming supply side.
Semiconductor devices can not be used as isolating devices.
For me the Internet has many billion semiconductor devices in it. Not to mention, as you highlight, being prepared to risk your life in the hands of a hung-over electricity supply person working from home to get it right.
Isolate the circuit. Lock it off and put the key in your pocket.
I'm pleased to hear that. However, in your initial post you were asking how you could operate the ('software controlled') switch/contactor within the meter, which seemed to imply that you were thinking of using it for isolation. Was that not the case?I agree with the regulation entirely and I’m fiercely agreeing with you that physical isolation is the only truly safe means of doing this.
My daughter's ('dumb') meter still has a built-in ('mechanical')isolator, which has proved very useful, and seems an obvious thing to do - but I've seen very few meters that have that.I remember hearing that, in the design brief for the smart meter, an isolator switch was included. Some of the later digital non-smart meters had such a thing.
This feature was removed as part of the inevitable cost-cutting process.
