What is standard thickness of wooden shead?
13 Apr 2011
Antrim
When buying a shed what should the minimum thickness of the wood used be?
what ever the specification says
could be made from 3 mm hardboard, not a good choice but will make a structure that will start as a shed -----for a short while
go fully by recommendation not price
many cheap shed will be around the 7-10mm mark
and word like"from 12mm stock" will be pre worked size and perhaps 9mm
you need to ask actual finished specs
