- Joined
- 11 Sep 2021
- Messages
- 25
- Reaction score
- 0
- Country
Hi
I’m hoping to improve the loft insulation of a cold roof of a large (c. 350m2) wood clad, timber frame bungalow that is currently poorly insulated and struggles with heat retention. It is currently largely single glazed (I’m working on secondary glazing with Magnetglaze Extreme Pro and 4-6mm Perspex). It’s been extended multiple times over several decades. Much of the construction appears to be wood clad single skin brick or breeze block with no insulation. Roof is a lightweight wooden structure with a thin metal roof tile (Decra Classic).
Given the poor thermal performance of the building, I’m inclined towards over-insulationg it / being overly cautious - unless of course that makes no sense.
There are a few options.
1. WARM ROOF
The roof will need replacing at some point, so one option would be to do that, and make it a warm roof (e.g. PIR boards, on the underside of the rafters, with a new metal or EDPM roof). Downsides are the significant cost of the new roof and PIR insulation, and the additional costs of heating the roof space (rather than just the rooms below, as with a cold roof). .
2 COLD ROOF
If going with a cold roof, I'd welcome some tips.
(A) Loft over bedrooms – currently partially insulated with loose fibre.
I imagine the plan would be:
(B) Skylight
There is a large skylight.
The (presumably plywood) wooden frame around it is partly insulated. Planning to:
- Remove existing insulation (and reuse elsewhere)
- Add downlight covers over LED lights*
- Add a v1000 gauge polythene vapour control layer over the plywood, studs and downlight covers (so there's a VCL on the warm side).
- Add insulation between the studs. These are c. 45-47mm. So I was thinking of 50mm compression fit Flexi Acoustic Slad Rockwool, or 40-50mm Rockwool RW3 (60kg/m3) for its acoustic performance, as well as thermal. Might be a bit tight compressing it ... 25 or 40mm seems preferable than risking a poor seal using 50mm. However, the Flexi only comes in 50mm, and it's hard to find RW3 in 40mm (unless you order a whole palette!).
- Clad over it all, studs included, with PIR boards. I was thinking 100mm (as part would need to be inside that secondary 100mm frame). Presumably securing, and taping over any gaps, with aluminium foil tape. Should the PIR go all the way to the roof membrane?
(C) Pipe lagging - recommendations welcome.
This may not be necessary - could just put loose fill insulation over?
(D) Acoustic isolation
I have an area that is decently insulated, but I'm keen to bolster the thermal and particular the acoustic isolation. Any tips on what to do here? Another 200mm of loose fill glass fibre on top? Concerned that using something more robust - like ROCKWOOL Twin Roll Insulation 100mm - will compress the glass mineral wool below ...
Comments on how best to approach this and recommendations for suitable materials (sizes, brands, etc), suppliers, etc would be most welcome. Keen to avoid condensation risk/damage to timbers, etc. And I guess a bit concerned that as some of the loft is used for storage, improving in the insulation at ceiling level exposes the roof storage space to greater temperate variations.
I’ve assumed that because I’m essentially topping up existing insulation that there’s little sense in changing horses on material, e.g. mineral wool or actual wool instead of glass mineral wool, but am open to ideas.
1. WARM ROOF
2 COLD ROOF
- Add downlight covers over LED lights. Loft Lids seem to be decent, and one of the least expensive options. Other suggestions welcome.
- Add more loose fill mineral wool where there is none between the joists (which are c. 220mm), so c. 200mm. Glass mineral wool? e.g. Knauff 40 or 44? Or Mineral wool? Or actual wool?
- Then add another layer (I assume 100mm – but perhaps 150-200mm worthwhile) everywhere over the joists/existing insulation.
- The problem with this is you then can't see where the rafters are, which means you can no longer safely move in the loft, which might be needed for access. Any tips on how to address that?
- For where the solar inverters/batteries, etc are, I'd need to create an access “walkway” (well, crawling patch) from the loft hatch to there for occasional access. This could either be done with 175mm Loft Legs, with chipboard on top (loose fill insulation under). Might PIR boards (75mm -100mm thick? E.g. Celotex GA4075 or GA4100) resting directly on the rafters work instead? Though I guess if they also need to be topped with chipboard or similar, there's little point and the Loft Legs solution would probably be just a cheap/effective, if not more so.
- Is it ok to leave the wires and pipes, and simply cover them with loose fill insulation? I think (/hope) the wiring's all low amperage - i.e. for LED ceiling lights. If so, I'm guessing that's not a problem. But who knows what all this wiring's for ... Not sure if there's a way of testing?
(B) Skylight
- Pictured from inside the loft:
- The other side is plasterboard into the room:
