We live if a property converted to 3 flats (~20 years ago). There is a single phase looped supply with 3 fuses 100A each (one for each flat).
UKPN are sending someone out but from phone conversations they expect (looking at a photo) they will need to be downgraded to 30A each or at best 60/30/30A. On the call they noted the main incoming appeared to be a Paper Insulated Lead Covered supply, from records a 60s install.
They suggested we should really have a 3 phase supply, and that we would have to pay for it. They said they wouldn't have installed it like that so it's not their cost to sort. This seems odd as the main fuse holder install is dated 2001 and all 3 fuses/holders look identical, and all wiring appears same age. If they/their predecessor didn't do it I'm not sure who did!?
30A seems ridiclous as we alone have two 20A ovens - not sure how a 30A would take that amongst other appliances? Surely it's going to blow every day?
When I queried this they said it might and just said that's not their problem, and they would likely replace it the first couple of times, and then inform us they won't carry out any further replacements as the supply needs upgrading.
Can they really just downgrade our fuses and then ask us to pay for a new 3 phase supply to serve the flats.
They also (IMO wrongly) installed the backing board in 2001 on a unsecure surface so the whole thing is loose on the wall. Even trying to get them to sort this they are suggesting is a cost to us as they will need to deenergise the supply to remove and remount.
Any thoughts or pointers to regulation on this woud be much appreciated.
