- Joined
- 28 Apr 2021
- Messages
- 318
- Reaction score
- 4
- Country
I have a 1.6m high retaining wall , 4m across, at the end of my garden, made of 2.6m x 125mm x 250mm sleepers which may be pressure treated or reclaimed , wedged into steel I-beams. They are layed directly onto the soil and soil and rubble behind the wall is directly in contact with it, no membrane. There are inch wide drainage holes every 80cm or so .
I had a look at the face of the wall which faces my neighbours garden, and there was a lot of rot, and one of the beams seems to have cracked in the middle and moved about 15mm. The beams are also a bit short for the I beams and are wedged in with bits of wood, also rotting.
Is this likely to collapse catastrophically ?Because I’d like to make a garden up top but I don’t want it to collapse into my neighbours garden.
Not sure what to do.
Last 2 pics are from my side up top, rest are from neighbours side
