    Dismiss Notice
Retaining wall questions - sleeper design
Discussion in 'In the Garden' started by jason61c, 6 May 2018.
  1. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    Hi all.
    I've 22M of retaining wall do build, 1.2m above ground level.
    I looked at blockwork, then rendered but wasn't keen on the look.
    So i'm going to go for untreated hardwood railway sleepers, 2.6m x240x150. Supported with I beams. I was going to do them vertical, however would a 5deg towards the garden be a better idea?
    How much beam should go into concrete? 600mm? Has anyone got any other ideas or thoughts?
    Thanks in advance.
  2. mikeey84
    mikeey84
    7 Jan 2011
    550
    Thanks Received:
    31
    Warwickshire
    Country:
    I'm no expert, but I am fairly sure that a retaining wall that high should be designed by a structural engineer due to the potential crush
  3. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    I don't think they do at this height? Its retaining soil, no heavy traffic, just garden. I could just shape bank and it wouldn't move, in theory :)
  4. Sunshine12
    Sunshine12
    13 Jan 2016
    228
    Thanks Received:
    Country:
    I have something similar 800mm high. The sleepers I have are 200mm when lay on side, otherwise 100mm when lay flat. Think 2.4m long. 100x200x2400
    Could you get a similar size then lay them horizontally, so that would 6 sleepers stacked (staggered joints) 6 @ 200mm = 1.2m, bolted through with HD coach bolts & 4 inch posts season spaced say every metre.
    Then fill the retainer with hardcore & slab.
    Use the sleepers for steps too?
  5. Halitosis
    Halitosis
    7 Oct 2014
    154
    Thanks Received:
    25
    West Lothian
    Country:
    I built a 1.2m retaining wall using those mortar-free blocks (Tobermore) - not cheap but at least easy enough for an amateur like me. I investigated the legalities regarding structural engineer, and this was the height limit (assuming not near a building or road as you say). Your sleeper idea sounds great - how about laying them horizontal but at a 5 degree angle to the face (Sunshine's excellent coach bolt suggestion could still be applied).
    Whatever you choose, drainage is critical - lay a field drain behind in pea-gravel with an outlet.
  6. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    The plan was for i beams(£40 each) to hold 5 beams on their side, I think that'd be stronger than bolting them? effectively every 2.6m i'd have an I beam.... Could I do without the beams and just bolt and stack?
  7. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    How did the tobermore's go? where did you get them from and what price? Seems like a decent solution?
  8. Halitosis
    Halitosis
    7 Oct 2014
    154
    Thanks Received:
    25
    West Lothian
    Country:
    Fantastic Jason. My wall is 15m long in total x 1.2m high (though I raised the patio so a little less visible). Building it was simple, even for a complete novice like me, as long as you get the base and first course of blocks level, its like lego from then on. 3 years later and it still looks as good as the day I finished it.
    Just looked up the invoice and I paid £7.55/unit... I think the "unit" was 1 linear metre of blocks and it totalled a little under £2k including VAT and coping. Secura Lite in Bracken. Some images are in this thread https://www.diynot.com/diy/threads/garden-levelling-retaining-walls-and-patio.436119/#post-3613497. I would have paid a similar price to get a tradesman to supply and build rendered blockwork, and I think the Secura looks much better. Also as its not mortared, it allows water through in the event of heavy rainfall, and (theoretically) if we ever move house I can disassemble the wall and take it with me :LOL:
  9. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    Thanks, although its now about £2.7k, so about £1000 more than sleeper materials, plus the extra work needed for the wall base etc.
    I do like the idea of taking them with you :)
  10. ger83
    ger83
    12 May 2018
    3
    Thanks Received:
    Country:
    We built this retaining wall with sleepers laid vertically, 720mm high. They are secured to the existing fence posts (after shaving off some of the concrete base) since they were deep enough. Where the joins didn't match the existing fence posts we drove an offcut down the back to pack it out.
    Previous owners built the brickwork but the top area still sloped towards the fence. We leveled it and put in the sleepers. Had no issues.
    [​IMG]
  11. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
  12. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    Took 9 days.
    35m of new drains/5 inspection chambers-man holes
    45 linear m of walls or more
    40 tonne of concrete buried
    150sq m of turf
    20 steel i beams
    20 tonnes of 803
    68 azobe sleepers at 90-120kg each
    3 tonnes of ballast
    12 bags of cement
    4 tonnes of pea gravel
    2 tonnes of sand
    100sq of geotex
    25m of land/french drain.
  13. Halitosis
    Halitosis
    7 Oct 2014
    154
    Thanks Received:
    25
    West Lothian
    Country:
    I bet the beer tasted good at the end of that... huge project - congratulations sir!
  14. jason61c
    jason61c
    22 Mar 2014
    291
    Thanks Received:
    7
    Devon
    Country:
    It did. Picked a nice hot week for it:cry:
Loading...
Share This Page
