Hi all,
Is there any reason, regulation or otherwise (aside from best practice) why pipes cannot be run within the cavity wall? I need to get 2x 28mm (CH F/R) and 2x 22mm (H/C) to a remote part of the house and currently have a large section of the cavity exposed due to having to replace flood damaged insulation and it would be an ideal route. Pipes would have no joins, would be insulated and then have the new wall insulation packed around them too. The alternative is to bury them in the floor which isn't ideal either.
The one thing I am aware of (I think) is that any pipes should be replaceable and whilst I appreciate that is a requirement on paper, the practice of doing so would be absolutely impossible. 28mm pipe being pushed through a conduit with multiple bends is just not going to happen.
Thanks in advance for any responses.
