Have to run new cold mains from plant room to kitchen for potable water at kitchen sink.
Previously the kitchen was used as a utility room and only had "grey" water supply to cold at sink.
Now been converted to kitchen and also another kitchen backing on to it and has to have potable water.
It would look better if I could run new cold feed externally for about 3 metres, under a canopy and down wall, outside, to enter behind plinths and up through sink carcass.
Anyone know of a suitable insulated ducting system that would prevent freezing in cold months?
I know about Insuduct but this is used mainly for 1 or 2, 32mm mdpe mains pipes and seems a bit oversized for this application. I only need something for 15mm run and would prefer to use a proprietary system rather than construct something stuffed with insulation.
Cheers.
Cheers.
