I know that, but since they both start leaking the moment I turn the screw, I want to cap them just for safety sake before removing the radiator.What do you actually want to do? Those valves are designed to interrupt the flow of whatever so are effectively capping the supply pipe already
I know that too and they will be as and when my plumber is in the area and comes to do my jobs.If they are leaking from the screw they are goosed and need chucking out.
And I also know that since another diynot member told me when the same type of valve was mentioned by me in a previous thread.those valves are not really suitable for heating pipe use anyway
Half inch BSP blanking cap nut and washer ,available from Screwfix and any plumbers merchants.I know that too and they will be as and when my plumber is in the area and comes to do my jobs.
What I really want to know is whether the required caps are universal fitting and if so, where can I order them from
Same problem I have.i have used these in the past when i changed a radiator and the valve did not turn off correctly.
Don’t know how I missed your post but just glad I found it second time round. I don’t have the expertise to remove the valve leaving the olive and nut! So I simply want to shut the valve, cap it (with your suggestion), and open it again to stop the leak at the screw. If I did remove the valve and flood the place, I wouldn’t know how to stop and my life wouldn’t be worth living! The pipes are microbore! Thank youBut i assume you will remove the isolation valve and be left with the pipe and olive and fitting
which I have also used
so this may do
Flomasta Brass Compression Stop Ends 15mm 2 Pack - Screwfix
Order online at Screwfix.com. Stop ends. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Should have mentioned I did get some rubber inserts with the cap itself , but i did add some washers tooIf you do temporarily use end caps, make sure that you have rubber washers in them. As a decorator, in the past, I have had to use use more than one washer in the end cap because the internal thread on the end cap was longer than the thread on the valve.
I think you should have mentioned that they are microbore in the first post.
I would have had I known that they were.I think you should have mentioned that they are microbore in the first post.
In a previous thread, it was suggested that valves shouldn’t have been used at all. I would imagine that the plumber will be using solder joins when he reconnects.I am not a plumber but would recommend that you ask your plumber to fit lever valves rather than those awful ball fixing valves.
I think the plumber will know that.If you do temporarily use end caps, make sure that you have rubber washers in them.
If they are connected to CH pipework to a radiator then you really need to get someone in to remove them and install proper fittings. They are not designed to be installed onto CH and will get worse of time, I have come across these on CH system before and they just leak constantly from the valve.I know that, but since they both start leaking the moment I turn the screw, I want to cap them just for safety sake before removing the radiator.
