- Joined
- 27 Sep 2022
- Messages
- 297
- Reaction score
- 23
- Country
Hello,
I am researching for a residential boiler. I have seen specs sheet for various boilers and they have written average gas rate as 1.8 m3/hr for 18 kw boiler.
I am interpreting that if the boiler runs for 1 hour at full load it will consume 1.8 m3/hr? Is it correct.
It is important for me to understand. I gas rated my existing boiler (non condensing, low pressure system, Central heating only) for 2 minutes and gas meter consumed 0.082 m3; multiply 0.082x30 = 2.46 m3/hr. I have logged its actual gas consumption on gas meter and with a total load of 8 kw it consumes 1.1m3/hr almost half of gas rated figure. I understand that with current load of just 8kw the burner is lit 3 times in one hour; 8 minutes on and 10 minutes off; it cycles on off roughly 3 times in one hour to consume 1.1m3/hr. It doesn't have any modulation controls, when setpoint (a sensor which is connected to the return line of the boiler) is achieved the burner turns off. I run the boiler at optimum settings and over the last two winters, I have managed to optimize it to its maximum in terms of gas usage (I think).
If I were to get a new boiler with spec sheet of 1.8m3/hr and if I take this figure as actual then I will not be saving any money? How can I be sure that new boiler will consume less gas than my existing gas boiler othern than that it will modulate and will be a condensing boiler. My plan is to get a system boiler and install it first for CH only and once I observe its gas savings in CH, I plan to install a Hot water cylinder to it as I have to supply water to 3 bathrooms and kitchen. I wouldn't mind a good condition used system boiler as it will be better than mine anyway.
Any ideas or thoughts.
Thanks.
Thanks.
